Enables MVRP on a given set of ports.
| mvrp | Multiple VLAN Registration Protocol |
| port_list | Port(s) on which MVRP is to be enabled. |
| all | All ports. |
Disabled.
Use this command to enable MVRP on given set of ports. MVRP is run on the MVRP enabled ports only if the global setting is enabled. By default, MVRP is disabled globally and on individual ports. When MVRP is disabled globally, all MVRP packets will be forwarded transparently. An error message is displayed if the user tries to enable/disable MVRP on a lag member port which is not the master port. No configuration changes are made.
The following command enables MVRP on ports 4 and 5:
enable mvrp ports 4-5
This command was first available in ExtremeXOS 15.3.
